S Snake12349 Reputable Mar 16, 2014 61 0 4,640 Apr 10, 2014 #1 Got everything hooked, fans are alright, led on mobo is on. No siginal? Tried different monitor but no luck, used HDMI and VGA out
Eduello Champion Mar 2, 2014 9,074 0 50,760 Apr 10, 2014 #2 System specs? Is your display plugged to the motherboard or to the GPU? Upvote 0 Downvote
S Snake12349 Reputable Mar 16, 2014 61 0 4,640 Apr 10, 2014 #3 Mobo : Asus z87-a Psu : XFX 550w core edition Gpu : Zotac gtx 770 1110mhz Ram : corsair 8gb vengeance pro 2110 MHz CPU cooler : h105 Case : 500R And it's connected through the mobo, the gpu hdmi doesn't work either Upvote 0 Downvote
Eddy Brockner Reputable Apr 7, 2014 3 0 4,510 Apr 10, 2014 #4 Have you tried the GPU DVI? Upvote 0 Downvote
Eduello Champion Mar 2, 2014 9,074 0 50,760 Apr 10, 2014 #5 Are you sure you connected all the power cables including the CPU and GPU cables? Also what's the CPU? Unplug/re-plug everything (including all power connectors and RAM). Then connect it to the GPU and start up your PC. If that doesn't help, clear the CMOS: http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm If you still can't get it to work, try using it without the GPU inside at all. Upvote 0 Downvote
