no single to monitor
Brennan Alexandria
i just built my first pc was grounded hole time installed everything but when i start it up it boots up properlyy but i get no signal to my monitor ive been looking at all these threads but still no luck my pc specs are
Seasonic M12II 620 Bronze 80 Plus Bronze 620W ATX PSU
Lite-On iHAS124-04 24x SATA DVDRW DVD Burner Dual Layer
TP-Link TL-WDN4800 2.4Ghz/5GHz 450Mbps Dual Band Wi-Fi PCIe Adapter
Sapphire Radeon R9 270X 4GB GDDR5 DVI-I/DVI-D/HDMI/DP Dual-X with Boost and OC version PCI-Express Graphics Card 11217-04-20G
Crucial Ballistix Sport 8GB Kit (4GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V UDIMM 240-Pin Memory BLS2KIT4G3D1609DS1S00
Seagate Barracuda HDD Internal Bare Drive 1TB
AMD FX Six-Core Processor Model FX-6300 3.5GHz Socket AM3+, Retail
Enermax Ostrog ATX Computer Case with Acrylic See-Thru Side Panel, Black/Blue ECA3253-BL
ASRock Fatal1ty 990FX Killer AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Gateway 21.5-Inch Full HD-1920x1280 LED Widescreen Monitor / KX2153 Cbd
Did you try a different cable to connect the graphics card to the monitor? Try DVI or VGA if you can.
Are you sure it actually is posting? There may be lights and spinning fans inside your case, but the computer still didn't properly POST.
I'd look at Tom's guide for building a new PC, and make sure you have all the checkpoints. Power cables, 1 stick of RAM, no peripheral hardware, no extra USB devices (Besides keyboard), PSU switch, single HDD, and so on. There are hundreds of posts about "New build won't boot". It could be dozen different things at this point.
