Question No sound after power blew out?
Aug 28, 2022
My power blew a few days ago and ever since my PC doesn't have any sound? I was playing a game with chrome and discord running in the background when it happened. A restart has not helped me, I uninstalled and reinstalled audio drivers, I went into services and restarted windows audio and changed permissions around ,I've simply waited and nothing. When the computer came back on I saw that it updated as well, so I tried rolling back to the previous update and its the same issue. What do I do? And now for some odd reason some of my hot keys are acting up, for example I always use [windows key + shift + S] and it'll let me crop a section of my screen and save it like a screenshot, but now when I do it I just get some weird yellow bars on my screen.
No applications are showing up in volume mixer l when I set windows audio services to local system account, and when that wasn't on I got a big X over the speaker icon in the bottom right of my screen.
When I reset my PC it'll say "could not open elgato sound capture driver". Please help I don't know what to do.
helpstar
Polypheme
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/system-file-check-sfc-scan-and-repair-system-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool
https://support.microsoft.com/en-us/help/4026994/windows-10-fix-sound-problems
Aug 28, 2022
clean boot
Unfortuntly none of these methods have helped me, and I am still stuck without sound
Aug 28, 2022
Is it a sound card or are you using the audio of your motherboard?
might be a hardware fault, get a new sound card (internal or external)
I am not using a sound card, I am using the audio directly off my motherboard. I don't know why the elgato popup is happening, since I only ever use it for streaming from my switch, and it still works
helpstar
Polypheme
try booting with a Linux distro like Ubuntu live on an USB flash drive, if sound is there, it should be the windows installation -> Reinstall windows
otherwise it should be a faulty motherboard, get a sound card/external USB sound adapter
