G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I recently purchased a Dell Dimension 5100 which arrived on time,
actually two days early. Everything is working fine except for sound.
(I am keeping my fingers crossed after some of the horror stories that I
have read in the newsgroup, but so far, so good.) I didn't order any
speakers figuring that I would just use the Boston Acoustics BA735 three
piece speaker system that I was using with my old Gateway, however when
I hooked them up there was no sound. Does the Integrated Audio card
included with the 5100 support digital stereo output? I thought it
would since it claims to have Digital 7.1 capacity.
I checked the Boston Acoustics website and they say that there have been
problems with getting the BA735 to work with Windows XP, but they only
gave links to Creative Sound and Gateway which I don't think would be
helpful with the 5100. The Dell site seems to be down.
Is there something that I need to do to enable digital stereo output
from the integrated sound card? Or is it only analog? If so, I guess I
could pick up a speaker cable with mini plugs on both ends and hook that
to the BA735's analog input.
If it is a Windows XP problem is there a patch or driver of some sort
that I can install?
I don't really need anything fancy like surround sound for the PC but I
would like some sound. If the 735 system isn't compatible, does anyone
have any suggestions for inexpensive speakers that would be?
Thanks,
Jerry
that I can install?
Thanks,
Jerry
