No sound from PC after new build
c00mba
Commendable
Jan 4, 2017
Hi all,
Built my first gaming PC(yay!!) everything works so far except for the audio.
I have tried uninstalling and reinstalling the drivers.
It shows that its there in the playback devices as Speakers (RealtekHd Audio) and the green bars move when something is playing or when i test it but no actual sound coming out of the PC.
I have also tried using speakers and headphones both in the front and back 3.5mm jacks and they also don't work.
Please help me.
Mobo: Asrock H110M-HDS
CPU: i3 6100
GPU: Sapphire AMD RX 460 Nitro 4Gb DDR5
Ram: Crucial 8Gb DDR4
Kingston 120Gb SSD
WD Blue 1Tb HDD
If you see the green bar moving, then it should be working.
Right click on it and set as default device in your playback devices - be sure to check and make sure that particular device isn't muted, and the volume is up.
It is set as default device and the volume is max and unmuted.
i have tried headphones in the front and back 3.5mm jack and also external speakers
