No sound in Mirror's Edge
Atlas1
5
I have a razer kraken 7.1 chroma usb headset. I plugged in another headset that has a jack instead of a usb headset and it worked, but I still want my usb headset to work, as it's the best headset I have, and my other ones are all low quality. I've heard of Mirror's Edge working on usb headsets before by the way.
If the headset you have thats USB has a built in soundcard you should be able to use both by going into your playback devices, right click show disabled devices, and enable both headsets, set your kraken as your default device.
