No sound, need HELP to fix. (Cambridge Soundworks DTT3500 Digital)
DarkoMedakovic
27
Hello.
So I have some old speakers that I've used for a quit long time now, (DT3500 Digital). They've worked perfectly fine until 2 days ago. The speakers just stopped working. I don't think the speakers are the problem now. My guess is the soundcard / amplifier or whatever it's called is dead. Now I need help getting a new one. So I hope some of you can help me find one.
Any suggestions?
Thanks in advance! 🙂
Its a bit of a late reply, but I hope its not too late to fix your problem. The 3 capacitors on the decoder/dsp/dac board inside the amplifier need to be replaced. If you have soldering skills or know someone who does you can fix this easily and cheaply. Id recommend replacing all the caps to be on the safe side. You might also consider replacing the filter caps on the powersupply board. Once thats done, it should be as good as new.
