New headset, plugged in with no sound. Checked control panel configurations, which looked OK with volume turned all the way up. Clicked on volume control on right ear & pop up shows high volume level, but still no sound.
Is the USB headset the default audio output device? Also, check to make sure the driver installed correctly; if not, you may need to do a manual driver install.
