No sound output from my laptop speakers
ahmodity
23
Hello. I'm having troubles using the speakers on my laptop, when I don't plug anything ( headset or speakers or etc ) it says that no audio output device is installed, however it works fine when I plug a headset or anything else. Troubleshooting said that it is a problematic Intel HD Audio Driver, they said if I restarted it would fix it. It didn't. I tried uninstalling it but it did nothing. Any help?
p.s this all started yesterday when I installed the April Windows 10 Update and I pressed Restart Now.
i think your audio driver is not capable with new april update
if you more lerning about your problem open EVENT VIEWER
start looking for hardwear logs
try to update your drivers if you can
