No Sound problem
majju2
116
"No speakers or headphones are plugged in" error on Windows 7
Basically everything was working fine before untill yesterday I dont have sound. Yes speakers are good tried them with my laptop, updated uninstalled and reinstalled drivers several time and speakers are connected properly.
os: windows 7 64bit
mobo: saberthoot x58
http://img683.imageshack.us/i/unledfy.png/
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, control panel, add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
look up your computer drivers by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
Let the forum know if that solves the problem. SGM
on some boards the firewall needs to be off when you load the audio drivers
I think it is software installation problem. You should choose another version of software. Have you ever tried Meridian Audio system ?
You should try it. Audio equipment of such high quality that if a microphone can detect it, the system can reproduce it. Video components so advanced they offer a uniquely realistic cinema experience.
http://www.meridian-audio.com
