No sound, something's not plugged in =(
RobtheSwede
75
5
18,545
Got no sound on my brand new custom PC, the drivers seems to be installed allright but when I go in sound settings it says this: "Digital Display Audio: AMD High definition audio device not plugged in." I mean what do they mean by this, did I miss plugging something in on the MB? Because all the cables are certainly plugged in.. =(
In the Taskbar, right click on the speaker icon. That will bring up a panel that will list all known audio outputs. Select the one that is your rear speaker outputs, and then set it to default on that same panel.
If that does not resolve the problem, open the Control Panel, click on Troubleshooting, and you will see an audio wizard in there.
