Okay, don't start by telling me to set the HDMI device as my default device. I know how it works.
My problem is,.even when my HDMI device is enabled, and should be working, there is no sound. I have always used the same HDMI cable and it has always worked, and the same set up I have now works perfectly fine through other TV's with the sound.
I noticed that in the device manager, the output property is set to 24bit, but my TV only supports 16bit? Then, when I try and change to 16bit so the sound will work, alas! I get a warning saying that my TV does not support 16bit. The whole situation is completely ridiculous. What is the problem? All of my drivers are up to date and working. I can get sound with headphones and all other devices, just not the TV.
Thanks in advance if anyone can help.
