• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
No Sound with DVI/HDMI & RCA-Y Cable
lpd
TV is a Philips 42PFL3603D/F7, Software is latest Status 1.15
Computer has an Intel DG43NB board with on-board DVI and 3.5 mm Audio Jack
Video - Connection is with DVI to HDMI cable to HDMI3 input at the TV
Audio Connection is a Y-RCA Cable from 3.5 mm Line Out to DVI Audio In for HDMI3
Video is OK, but no Sound. When I pull the HDMI cable and leave the RCA-Y cable in, restart the computer I have sound, but no video. As soon as I plug in the HDMI, video is there, but no sound.
The same computer and setup works perfectly with a Samsung Synchmaster LCD TV having both, video and sound, only the Philips is trouble. Obviously the Philips gets confused from any noise on the HDMI input and ignores the RCA connection. The Philips software has no possibility to ignore HDMI audio in and therefore to take the RCA. As per the manual, HDMI3 should work with the DVI Audio in for HDMI3, but it doesn´t. Only when the HDMI cable is pulled.
As the mainboard is no HDMI but DVI only there is no possibility in the BIOS to disable any HDMI audio. I can only disable all audio, but that wont help either.
Any ideas, other than working with the Samsung instead of the Philips?
jcoultas98
634
46
Make sure you don't have the computer's HDMI trying to send sound to the TV. In your control panel, make sure your default sound device is your onboard sound device. In many cases, HDMI devices will default themselves in windows when they are detected.
