No System fans slot on motherboard
lokesh_22
6
I have a Gigabyte motherboard GA-B250M-Ds3H which comes with one system fan header . i have 120 mm 5 system fans and my motherboard only 1 sys fan header. Is there any way to do this ?
Yes. You can use a fan hub if you simply want to plug the fans in and let the system automatically control them.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811999300&cm_re=fan_hub-_-11-999-300-_-Product
If you want manual control and setting fan curves etc... you will need a fan controller.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811992013&cm_re=fan_controller-_-11-992-013-_-Product
I've used both items. They work just fine. I currently have the NZXT fan controller, its pretty awesome.
MERGED QUESTION
Question from lokesh_22 : "No System fans slot on motherboard"
