No VGA monitor signal - graphics card works properly in device manager
blokeybloke
16
Hi, really need help with this.
I get 3 beeps and no monitor signal.
New graphics card, R7850. New psu, cx600.
MS-7800 motherboard, a8-5500 apu with hd 7560d onboard graphics.
I've plugged a vga monitor into the correct port with a dvi connector.
The new card appears in device manager, working properly.
Any help would be massively appreciated.
blokeybloke
16
Sorry, never occurred to me to look up beep codes.
1 long and 2 short seems to be monitor or display card error.
Incidentally, there are no empty power sockets on either the motherboard or the graphics card.
Don't understand how the card can be appearing in the device manager working properly. I've updated the drivers as well, by the way.
blokeybloke
16
Found this for my bios (Aptio)
PEI beep codes.
3 beeps: DXEIPL was not found, DXE core firmware volume was not found.
Do I need a new motherboard to run this card?
Thanks.
blokeybloke
16
Hi,
There was no additional info.
Just tried the card on another pc with same type of pcie slot and it worked.
There's one circular battery on my motherboard, so I guess that's the cmos one?
Thanks for your advice.
Similar threads
