No VGA Signal, Everything was running ok but now isnt
Vixkzu
23
So I've had this build for about 3 weeks, recently I did a motherboard swap and the computer ran fine for a day. Yesterday i was using my computer for about 5-8 hours and left for an hour to do some stuff. I came back and the computer monitor is black, and a vga light was red. I thought it was my motherboard so i swapped it back to my original one. Same problem, same situation. No connection to Monitor and the keyboard and mouse isnt working
UPDATE: the cpu is fine, the ram is fine, when i turn on the system, my gpu detects 2 of my 8 pin connectors, then drops one and the red VGA LED light turns on. I rearranged the psu vga cables to 1&2 instead of 2&4 . same problem
i dont think so, i disassembled everything and put it all back together (evga 650 modular psu gold) when i turn on my computer the fans go on and the LED for the gpu go on aswell, but theres no conneciton
different mobo and chipset. went from 970 to 990x, i then swapped it back to 970 after having the no vga detection. vga still isnt being detected in old mobo, neither does the kb and mouse
Fx 6300
Hyper 212 evo
Asus M5a99x Evo R2.0
kingston hyper x ram 2x4
Sapphire 280x tri-x (vapor x)
EVGA Supernova NEX 650 80+ gold full modular
this psu :https://www.evga.com/Products/Product.aspx?pn=120-G1-0650-XR
