[SOLVED] No vga signal please help
Dec 3, 2019
14
I have just build my first pc and I'm having trouble with a no vga signal to monitor.
It has a
Asus m4n68t motherboard
500gb data Western digital hard drive
Gigabyte 2 Gb graphics card
Am3 CPU
500w psu
New 4gb ddr3 ram
I want to know if the motherboard I'm using has on board graphics so I don't have to use graphics card.
It has a vga input on the motherboard itself and when I connect it and remove graphics card nothing
It is a new hard drive and I haven't installed a os yet
Nov 29, 2019
61
once you post, get into bios and check onboard graphics, if it does not exist use GPU. why would you even want to use onboard graphics when you have a functional GPU?
Nov 29, 2019
61
change PSU ASAP, use GPU graphics, install neccesary drivers, get the corsair I told you, and clean install Windows, and get a new GPU if you are on a budget I suggest an RX560 or an RX580/590 from AMD starting at £150
Nov 29, 2019
61
Where is your RAM?, please tell me you wont be gaming with 4GB?, for the love of GOD get 2x4gb Hyper X fury DIMMS, they're £55, or get 2X8GB DDR4 from hyper X, 8 is recommended but 16GB is what you should have
Nov 29, 2019
61
Here Ill build you a PC using your mobo-
GPU- AMD RX570/580/590 (whichever you prefer)
PSU- Corsair VS650
RAM- 2x8GB DDR4 HyperX fury
SSD- Samsung Evo860 500gb
Dec 3, 2019
14
I have just built my first pc I'm a novice specs
Amd ii CPU
Samsung 4gb ram
Western digital sata 500gb drive
400w gaming psu
I turn it on and the monitor goes into sleep mode showing no vga signal the CPU fans external fan light up and the motherboard shows a green light. But no display running off motherboard vga port not video card as my gigabyte graphics card is faulty will post video soon any ideas are greatly appreciated any info needed just ask and I'll reply
