[SOLVED] No video after post problem
Raynedog00
Commendable
Dec 17, 2016
9
Ok guys I have a
asrock fatality x370 gaming x mobo
A PNY branded 1050 ti 4gb
16gb/ 2x8gb mushkin ddr4
A corsair cx 650m bronze psu
A ryzen 5 1600 with stock cooler
A PNY sata 150gb ssd
And a Seagate 1tb hdd.
Here's my problem. Was watching YouTube, left to get some lunch. Came back and my PC was in sleep mode like expected. Went to get it out of sleep and it wouldn't. Restarted by depowering by holding button. Afterwards it wouldn't post. Gave me error 62 which is installation of southbridge runtime services. It was also giving me a memory error code.
I went through the checklist. Used 1 ram dimm in each slot, reset cmos by short connector and by battery removal. Left it with just GPU plugged in, left it with everything but GPU. I've tried an old gpu I have laying around. The weird part is now, it's running through its post cycle normally. Isn't getting hung up on codes and then my diag screen on the mobo shuts off as normal, but I still have no screen. All fans work on all components which they were before. Rgb works. It will detect no gpu installed, it will detect no ram installed, it will detect no sata drive installed. But still no screen. My keyboard volume control works as I get noise in my headset though it's not a windows noise, just interference noise. I'm really stumped at this point. My bios has several updates available, but I can't run the updater if I have no screen. I do have it saved to a flash drive as I have access to my roommates PC.
Never mind, it seems to have fixed itself. Going to do update bios while I can. Then look at getting a new GPU as it's the oldest part in this rig that could have been the culprit.
