Question No video output and Flashing cpu and ram led
Mar 29, 2019
8
Okay so yesterday I turned my computer off by switching the power supply switch straight off without shutting down or anything. Now I receive no video output and the cpu and ram leds are flashing on my mobo. I'm not sure what could be the problem or how I cant find the problem. It's a very new build. Thank you for any help
Mar 29, 2019
8
And why would you do that .... :oops:
Anyway,tried a clear cmos? Might want to reseat parts like ram and gpu,maybe it will help.
Okay, I'll attempt these when I get the chance, i honestly didn't think it could damage anything. What part/s would most likely be damaged?
Well normally it won't really damage anything,it might screw up windows. But you do have problems so something happened. There is just no reall reason to shut down a pc like that unless you're testing while breadboarding.
Mar 29, 2019
8
Well normally it won't really damage anything,it might screw up windows. But you do have problems so something happened. There is just no reall reason to shut down a pc like that unless you're testing with breadboarding.
Yeah now that I think about it is was pretty stupid, if any of those dont work, what should I do?
