Hi all, quick question:
So, a few months back I started having an issue where my desktop would boot into the BIOS, I would F10 to get into windows and find that my date/time was incorrect on the PC. This happened every time I booted the PC (I fully turn off the power supply and turn off the surge protector when I turn the PC off to save on power, it's just a habit). After some quick research, I found that this was probably caused by the CMOS battery on the motherboard going dead. Okay, no big deal. Seemed like an easy enough fix.
After a bunch of procrastination on replacing the battery and just dealing with the time/date being wrong, I finally replaced the battery last night. My motherboard (Asus ROG Strix Z370-E) happens to be a model that has the battery located directly under the PCI-e slot for the GPU (GTX 1080Ti). So I removed the CPU cooler (required to reach the latch to unlock GPU), unlatched and removed the GPU, replaced the battery, and put everything back in place. No big deal. No hiccups on reconnect. Everything snapped back in place without any issue.
Now, however, when I try to boot the PC I'm not getting any video signal to the monitor. I've tried using DP, HDMI, multiple monitors, and even tried using the motherboard's on-board display connections. Nothing gets a video signal to the monitor, no matter what. I've taken everything back apart several times, checked all wired connections, replaced the CMOS battery with the original + with a 2nd new one, and nothing seems to change. All fans turn on, all relevant LED's turn on (I think), everything appears to turn on like normal, but no video signal.
Is there anything else I'm missing? Is there something else I need to do when replacing the CMOS battery or another step I can try?
Please note, I'm not a huge tech guy. I built this PC, and have built a few in the past, but beyond the very basics I don't know much. So I apologize in advance if I ask for additional explanation on any possible solutions.
Thanks!
Thanks!
