No wireless networks found in range?
K. I unselected it.
I've got no reall idea. Mybe the wireless adapter is a dead part? Would need to test in another computer to verify.
But it sounds like everything should work.
It's enabled, installed, set to auto..etc. It should work. I say should.
I've found in the past that when Windows wireless wasn't picking anything up.. Whatever utility came with the wifi adapater sometimes does a better job.
Does it even show up as a network connection in network adpaters?
Check services.. do you have a service called Zero Config Wireless.. (or something llike that) disabled?
Is the adapter set to DHCP? Is there a static ip set against it?
Yes.
Ready activated.
Um... what?
If you look in netowrk connection.. see your wireless adapter, right click and goto properties.
Then there is a list with some stuff.. IPv4 (it might just be plain old TCP/IP in XP - it'S been so long i can't reember exactly)
Double click on that.
Is it set to obtain an address automatically? (it probably should be!)
Also.. i s the adapter and woreless router compatable? You haven't go AC only wifi router for example and a b/g/n only adapter?
It is.
It is wireless.
I accidentally chose you as a solution...
K. I unselected it.
