No Wireless Networks
SeeSaw
Own build computer. Asus K8V-XE motherboard
Attempting to Connect Wirelessly
BT Openreach modem: B-Focus V-2FUB/r
Plusnet technicolor TG582n router
Fibre Optic Internet
Computer is about 5 m from rotuer
MiniToolBox by Farbar Version: 21-07-2014
Ran by (administrator) on 31-12-2006 at 23:04:40
Running from "E:\"
Microsoft Windows 7 Professional Service Pack 1 (X64)
Boot Mode: Normal
========================= Flush DNS: ===================================
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
"Reset IE Proxy Settings": IE Proxy Settings were reset.
========================= FF Proxy Settings: ==============================
"Reset FF Proxy Settings": Firefox Proxy settings were reset.
========================= Hosts content: =================================
========================= IP Configuration: ================================
VIA Rhine II Compatible Fast Ethernet Adapter = Local Area Connection (Media disconnected)
TP-LINK 300Mbps Wireless N Adapter = Wireless Network Connection (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . :
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : TP-LINK 300Mbps Wireless N Adapter
Physical Address. . . . . . . . . : E8-94-F6-99-7F-57
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : VIA Rhine II Compatible Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-1B-FC-05-AC-3E
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Server: UnKnown
Address: 127.0.0.1
Ping request could not find host google.com. Please check the name and try again.
Server: UnKnown
Address: 127.0.0.1
Ping request could not find host yahoo.com. Please check the name and try again.
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time=1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
Interface List
13...e8 94 f6 99 7f 57 ......TP-LINK 300Mbps Wireless N Adapter
11...00 1b fc 05 ac 3e ......VIA Rhine II Compatible Fast Ethernet Adapter
1...........................Software Loopback Interface 1
14...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
1 306 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (12/31/2006 11:02:47 PM) (Source: WinMgmt) (User: )
Description: //./root/CIMV2SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 990x80041003
Error: (08/14/2014 10:40:15 PM) (Source: WinMgmt) (User: )
Error: (12/31/2006 11:15:58 PM) (Source: WinMgmt) (User: )
Error: (12/31/2006 11:07:53 PM) (Source: WinMgmt) (User: )
Error: (12/31/2006 11:05:13 PM) (Source: Application Error) (User: )
Description: Faulting application name: daemonu.exe, version: 1.10.8.0, time stamp: 0x510a1ef6
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x719f71fc
Faulting process id: 0x98c
Faulting application start time: 0xdaemonu.exe0
Faulting application path: daemonu.exe1
Faulting module path: daemonu.exe2
Report Id: daemonu.exe3
Error: (12/31/2006 11:02:46 PM) (Source: WinMgmt) (User: )
Error: (08/07/2014 08:50:54 PM) (Source: Microsoft-Windows-CAPI2) (User: )
Description: Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab> with error: A required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.
Error: (08/07/2014 08:50:53 PM) (Source: Microsoft-Windows-CAPI2) (User: )
Error: (08/07/2014 08:03:50 PM) (Source: Microsoft-Windows-CAPI2) (User: )
Error: (08/07/2014 07:06:53 PM) (Source: Desktop Window Manager) (User: )
Description: The Desktop Window Manager has encountered a fatal error (0x8007000e)
System errors:
Error: (12/31/2006 11:16:53 PM) (Source: Service Control Manager) (User: )
Description: The Windows Modules Installer service terminated with the following error:
%%16405
Error: (12/31/2006 11:10:00 PM) (Source: DCOM) (User: )
Description: {752073A1-23F2-4396-85F0-8FDB879ED0ED}
Error: (12/31/2006 11:05:16 PM) (Source: Service Control Manager) (User: )
Description: The NVIDIA Update Service Daemon service terminated unexpectedly. It has done this 1 time(s).
Error: (12/31/2006 11:05:13 PM) (Source: Service Control Manager) (User: )
Description: The ZoneAlarm Privacy Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
Error: (12/31/2006 11:04:34 PM) (Source: Service Control Manager) (User: )
Description: The Windows Defender service terminated with the following error:
%%32
Error: (12/31/2006 11:04:09 PM) (Source: Service Control Manager) (User: )
Description: The Windows Font Cache Service service terminated with the following error:
%%32
Error: (12/31/2006 11:03:51 PM) (Source: Service Control Manager) (User: )
Description: The Print Spooler service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
Error: (08/07/2014 08:50:31 PM) (Source: Service Control Manager) (User: )
Description: The Windows Modules Installer service did not shut down properly after receiving a preshutdown control.
Error: (08/07/2014 08:26:47 PM) (Source: Service Control Manager) (User: )
Description: The Windows Update service did not shut down properly after receiving a preshutdown control.
Error: (08/07/2014 08:26:11 PM) (Source: Microsoft-Windows-WindowsUpdateClient) (User: NT AUTHORITY)
Description: Installation Failure: Windows failed to install the following update with error 0x800f0902: Update for Windows 7 for x64-based Systems (KB971033).
Microsoft Office Sessions:
Error: (12/31/2006 11:02:47 PM) (Source: WinMgmt)(User: )
Error: (08/14/2014 10:40:15 PM) (Source: WinMgmt)(User: )
Error: (12/31/2006 11:15:58 PM) (Source: WinMgmt)(User: )
Error: (12/31/2006 11:07:53 PM) (Source: WinMgmt)(User: )
Error: (12/31/2006 11:05:13 PM) (Source: Application Error)(User: )
Description: daemonu.exe1.10.8.0510a1ef6unknown0.0.0.000000000c0000005719f71fc98c01c72d2ffb6c2ee5C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exeunknown5e3f3f21-9923-11db-9bd8-001bfc05ac3e
Error: (12/31/2006 11:02:46 PM) (Source: WinMgmt)(User: )
Error: (08/07/2014 08:50:54 PM) (Source: Microsoft-Windows-CAPI2)(User: )
Description: http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cabA required certificate is not within its validity period when verifying against the current system clock or the timestamp in the signed file.
Error: (08/07/2014 08:50:53 PM) (Source: Microsoft-Windows-CAPI2)(User: )
Error: (08/07/2014 08:03:50 PM) (Source: Microsoft-Windows-CAPI2)(User: )
Error: (08/07/2014 07:06:53 PM) (Source: Desktop Window Manager)(User: )
Description: 0x8007000e
=========================== Installed Programs ============================
Adobe Flash Player 14 Plugin (HKLM-x32\...\Adobe Flash Player Plugin) (Version: 14.0.0.145 - Adobe Systems Incorporated)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 (HKLM-x32\...\{9A25302D-30C0-39D9-BD6F-21E6EC160475}) (Version: 9.0.30729 - Microsoft Corporation)
Mozilla Firefox 31.0 (x86 en-US) (HKLM-x32\...\Mozilla Firefox 31.0 (x86 en-US)) (Version: 31.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 31.0 - Mozilla)
NVIDIA Control Panel 307.83 (Version: 307.83 - NVIDIA Corporation) Hidden
NVIDIA Graphics Driver 307.83 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 307.83 - NVIDIA Corporation)
NVIDIA Install Application (Version: 2.1002.109.706 - NVIDIA Corporation) Hidden
NVIDIA Update 1.10.8 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Update) (Version: 1.10.8 - NVIDIA Corporation)
NVIDIA Update Components (Version: 1.10.8 - NVIDIA Corporation) Hidden
TP-LINK TL-WN881ND Driver (HKLM-x32\...\{FDA7E907-6539-42C1-9721-0239C281B336}) (Version: 1.3.1 - TP-LINK)
ZoneAlarm Antivirus (x32 Version: 13.3.052.000 - Check Point Software Technologies Ltd.) Hidden
ZoneAlarm Firewall (x32 Version: 13.3.052.000 - Check Point Software Technologies Ltd.) Hidden
ZoneAlarm Free Antivirus + Firewall (HKLM-x32\...\ZoneAlarm Free Antivirus + Firewall) (Version: 13.3.052.000 - Check Point)
ZoneAlarm Security (x32 Version: 13.3.052.000 - Check Point Software Technologies Ltd.) Hidden
ZoneAlarm Security Toolbar (HKCU\...\zonealarm) (Version: 1.8.29.17 - Check Point Software Technologies LTD)
ZoneAlarm Security Toolbar (HKLM-x32\...\zonealarm) (Version: 1.8.29.17 - Check Point Software Technologies LTD)
========================= Devices: ================================
Name:
Description:
Class Guid:
Manufacturer:
Service:
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
Name:
Description:
Class Guid:
Manufacturer:
Service:
Name: Multimedia Audio Controller
Description: Multimedia Audio Controller
Class Guid:
Manufacturer:
Service:
========================= Memory info: ===================================
Percentage of memory in use: 73%
Total physical RAM: 1022.49 MB
Available physical RAM: 275.33 MB
Total Pagefile: 2046.49 MB
Available Pagefile: 989.2 MB
Total Virtual: 4095.88 MB
Available Virtual: 3991.59 MB
========================= Partitions: =====================================
2 Drive c: () (Fixed) (Total:117.07 GB) (Free:89.61 GB) NTFS
4 Drive e: (Expansion Drive) (Fixed) (Total:232.88 GB) (Free:51.15 GB) NTFS
========================= Users: ========================================
User accounts for \\
Administrator Guest
UpdatusUser
========================= Minidump Files ==================================
No minidump file found
========================= Restore Points ==================================
07-08-2014 01:48:16 Installed TP-LINK Wireless Configuration Utility and Driver
07-08-2014 01:48:54 Installed TP-LINK Wireless Configuration Utility
07-08-2014 01:51:09 Windows Update
07-08-2014 14:11:59 Windows Update
07-08-2014 20:07:24 Windows Update
14-08-2014 22:35:46 Removed TP-LINK Wireless Configuration Utility
**** End of log ****
Im trying to resurrect an old computer of mine. I've got a clean install of windows 7 and I put in a new wireless card (TP- Link 300mbps Wireless N Adapter) I installed the utitly and drivers and I was able to find my wireless network and connect. As soon as I try to use the internet the connection disconnects and the wireless card is unable to find my home network as well as any other networks in the area which it was able to see before.
When I restart the computer it will be able to find my network and other networks. When I connect it very quickly disconnects and cant find any networks. I have a laptop in exactly the same position which can connect no problem.
I need to replace the CMOS battery which I will be doing very shortly but I dont know if this can have any effect on the wirless card?
Thanks in advance.
