I'm upgrading my mobo/CPU to an i7-4790 (socket 1150). My rig previously had an old i7-920. (socket 1366)
I had a Noctua NH-U12P on the 920, and its been awesome. I'm curious if I can re-use it on the new setup (since I'm using the same case and know it fits). I know Noctua is awesome and sells kits to change the socket type on some of their heatsinks but I found their website confusing and couldn't seem to buy anything from it.
Has anyone had experience with such kits? How did you find/figure the right sized kit?
Thanks in advance
Thanks in advance
