I just bout the Noctua NH-U12S CPU cooler for my pc but my motherboard apparently has an automatic cpu fan setting that i need to disable in order for the fan to get the required voltage. The problem is since this is a new computer i dont know my way around the BIOS at ALL and im not sure if i would be ok just running it on the heat sink by itself until i can find the correct setting. So would it be safe to run an AMD FX 8350 with just the heat sink just in the BIOS?
