Hi, the last PC I built I had a i5-6400 cpu and as u know that comes with a stock fan. My new build is going to have an i7-8700k and I’m going to get a Noctua NH-D15 for it. From what I’ve read the nh-d15 is massive. There’s 4 things I’m scared about. 1) Will my ram fit under it? (I’m going to get Corsair vengeance lpx 16gb 3000mhz). 2) Do I install everything before I put in the nh-d15 or do I install it outside the case or install in the case but before everything else?. 3) When it’s installed will I have enough room to plug in cables? 4) when I put the thermal paste on the cpu, I read that you want to put a small grain of rice, but do I spread it or leave it alone?
In the end I’m going to get the nh-d15, it’s just that I would love some installation device. Btw here’s my build:
Was wondering if everything works together
Monitor: Acer Predator XB271HU 27" WQHD (2560x1440) NVIDIA G-SYNC IPS Monitor, 144/165Hz
Case: Phanteks Pro M
Cpu: Intel Core i7-8700K
GPU: EVGA GeForce GTX 1080 Ti SC2
Mobo: ASUS PRIME Z370-A LGA1151
RAM: Corsair Vengeance LPX 16GB 3000MHz C15
CPU Cooler: Noctua NH-D15
SSD: Samsung 860 EVO 250GB (from my old pc)
Hard Drive: WD Blue 1TB SATA 6 Gb/s 7200 RPM (from my old pc)
