[SOLVED] Noctua nh d15 which way to place?
Im going to be building soon, how do I know if its going back front to back? lol
The case fans are preinstalled as such:
2x 200mm front intake
1x 120mm rear exhaust
Mounting the D15 vertically won't be as efficient without some top exhaust fans - also, you'd have to move the gpu to the 2nd PCIE slot, or you'll have to remove the front fan to make it fit.
H500P Mesh here.
If you're not adding to the 3x preinstalled fans, then the D15 should be front-to back.
If you are adding fans, I'd say experiment a little.
Scenario 1 - NH-D15(front to back)
Front intake: 2x 200mm
Rear exhaust: 1x 120mm
Top exhaust: 2x 120mm, 1x 140mm, or 1x 140 and 1x 120
Scenario 2 - NH-D15(bottom to top)
Top exhaust: 2x 120mm or 2x 140mm
I could go on, but I'll stop there for now.
H500P Mesh here.
Wont be adding any fans as of now. so will go front to back! cheeers
Reactions: Phaaze88
H500P Mesh here.
