Hi guys,
I wonder if this is the right position for that cooler:
https://www.google.se/search?q=noctua+nh+d+14+position&biw=1920&bih=979&source=lnms&tbm=isch&sa=X&ei=RIvuVODSOcPaOLqMgegJ&ved=0CAYQ_AUoAQ#tbm=isch&q=noctua+nh+d14+am3%2B+position&imgdii=_&imgrc=b_xr86abTSzuuM%253A%3BsusZ11RszMQylM%3Bhttp%253A%252F%252Fwww.guru3d.com%252Fmiraserver%252Fimages%252F2009%252Fnoctua-nh-d14%252FIMG_9611-600.jpg%3Bhttp%253A%252F%252Fwww.guru3d.com%252Farticles-pages%252Fnoctua-nh-d14-review%252C5.html%3B600%3B442
I have the exactly same position, i searched online and I see other people that point it in different direction, I don't have top fans mounted only the exhaust - back of the case and one in front (intake)
I really want to know before I have to remount this tower cooler
I didn't connect the "ultra low noise" adapter that came with the cooler, is that necessary? (it is a bit loud) is it possible to change that in bios instead?
EDIT:
I changed the position of fans and got much lower temps!
Btw, for those that consider buying Noctua Nh-D14, the installation was very EASY compared to previous cooler master hyper evo 212
Thanks all for the help!
EDIT:
