I just came back from the store and as you can see in the picture the fan of the Noctua NH-U12A chromax cannot sit properly because the memory (2) "gets in the way" - The fan then sits above the ram stick
The case is Fractal Design Torrent Black Solid btw
I'm afraid I have to compromise on the cooling of the processor (Intel Core i9-13900K) - How does such a thing happen on such a large motherboard?
I don't know what to do
Will there be a difference in the temps because of it? Did the seller install something wrong? Are the sticks of 2 and 4 necessary for the stability of the system? (3 and 4 will make instability?)
I'm going back to the store tomorrow to complete the built of the pc - any advice and tips are welcome!!
