Noctua Or Coolermaster (Fans) Help!!!
ChrisTsall99
702
Hello
So what do you think guys this Cooler Master Fan JetFlo 120 Dark 120x120x25mm or Noctua Fan NF-F12 PWM 120x120x25mm I want to buy 2 fans because I don't have any at the moment ... I want performance I don't care about noise or something I just want to have a good airflow .
Jetflo's have decent numbers SR-71, that being said, they'll be louder and won't have the lifespan. If you get the Noctua industrials, they'll be fairly loud at top speed, but if you can get them to 1500rmp or so, they'll be pretty quiet.
So u suggest me Noctua?
Yep. The jeflo's aren't as bad as SR-71 suggests(I own one). But they're not as quiet as a Noctua at similar rpms and they won't have the same lifespan. I own a bunch of different Noctua fans, they're the best at pretty much any performance level. They're not cheap though.
Noctua F12 PWM or NF S12A PWM which one is going to have better airflow?
Thanks for your time
I have the F12 PWM. I don't own a S12a. The F12 can be run at max rpm and it's barely perceptible(this matters, you can count on it's performance at all times). It's a real sweet fan, it would be my choice.
Thanks for your time really appreciate it :)
