Noctua's white fans have been taken off the menu, and its next gen 140mm fans and NH-D15 CPU cooler kicked down the road.
Noctua's White Fans Disappear From Roadmap : Read more
The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
look at the market of "white" stuff in the market for your answer.How hard is it to take the existing fan design and change the plastic from brown to white?
Which brands would you consider on par with them, performance-wise?At this point I think they're that "Apple" of fans. So many other vendors have caught up or passed them in both performance and cost, and yet, the fan club remains... Of course they want to be a "brand" or "status symbol" as this is where the big bucks are. People love to pay extra for status symbols.
I really like to see reviews which also test all coolers with the same fan(s), though. Otherwise, someone can compensate for an inferior cooler with a noiser, higher-flow fan. Obviously, if a cooler is designed to use a 140 mm fan, you don't test it with a 120 mm, but the 140 mm you use should be from the same family as the one you use for testing 120 mm and 90 mm coolers.Here's a pretty good benchmark comparison from a Scythe FUMA2 review, and you can see where the air coolers sit compared to the competition. For reference, the top air cooler in the chart are the DeepCools with the NH-D15 next (and the Skythe behind it). The coolers above them are all liquid:
Scythe FUMA2 Rev.B CPU Cooler review
Scythes new Fuma 2 Rev.B cooler now features two 120 mm PWM fans that can produce up to 67 CFM for increased cooling capacity. The cooler is now also compatible with Intel's LGA1700 socket, ideal for... Processor overclocking with Higher Voltagewww.guru3d.com
Noctua don't use a standard plastic for their fan rotors. They use a proprietary liquid crystal polymer, which is stiffer and more dimensionally stable than polycarbonate or PBT. This allows for tighter clearances between the rotor tips and the fan shroud and reduces vibration of the rotor blades, both of which are important for reducing noise. The disadvantage is that they can't just buy material off the shelf.What I don't get is this: How hard is it to take the existing fan design and change the plastic from brown to white? Shouldn't that be a trivial change?
Not when you have to invent a new plastic first.How hard is it to take the existing fan design and change the plastic from brown to white? Shouldn't that be a trivial change?
excellent observation.If you really care about quality, there's no such thing as a trivial change.
Still seems crazy. I mean, I'm not materials scientist, hence the question marks on my post. But white plastic versus brown... isn't the brown the one that has pigment, and the white would lack the pigment? I get that there's a lot involved with this, but it reeks of things like Razer spending $500,000 to get just the right shade of neon green for its USB ports. There's attention to detail, and then there's obsessing over minor things than 99% of people will never notice. 🤷Noctua don't use a standard plastic for their fan rotors. They use a proprietary liquid crystal polymer, which is stiffer and more dimensionally stable than polycarbonate or PBT. This allows for tighter clearances between the rotor tips and the fan shroud and reduces vibration of the rotor blades, both of which are important for reducing noise. The disadvantage is that they can't just buy material off the shelf.
More broadly, injection molding is a much more complicated process than you might imagine. If you're trying to maintain tight tolerances and you have precise requirements for mechanical properties and aesthetic appearance, there are a huge number of variables that need to be carefully controlled. The addition of a pigment can change the material properties of the finished product, affect flow of plastic through the mold and change the rate of shrinkage and the subsequent internal stress. If you really care about quality, there's no such thing as a trivial change.
In some areas, yes. I probably wouldn't pick them for a new desktop build without a good deal. Picked a Dark Rock Pro 4 for my brother.At this point I think they're that "Apple" of fans. So many other vendors have caught up or passed them in both performance and cost, and yet, the fan club remains...
