Question Node 202 CPU cooler.
rtmace750
37
I am looking for the best CPU cooler that I can fit into the Node 202. I know about the Noctua one but that’s all I can really find that will fit that isn’t the stock wraith stealth since the c7 has dropped out of existence. I was going to get the c7 cu. Any and all coolers that will fit is appreciated as I cannot find very many thanks!
I had been doing some research on a Node 202 build a while back and remember finding something that you can actually squeeze 59mm/60mm coolers into it. Possibly without the dust filter installed. That would get you into something like the:
Cooler Master Gemin II M4
Reeven Stereopes or Brontes
BEST: You can also get a 120mm AIO in a Node 202 if you use an "ITX" GPU and widen and heighten the hole in the case cross-bar so you can get the water block through it. Bitwit cut the cross bar (see 12:00 in video) but his cut-out allowed more room for the tubing. I'd probably try leaving the horizontal flange in tact and just cut upward to it to preserve rigidity.
You can also get a 120mm AIO in a Node 202 if you use an "ITX" GPU.
Thanks for the suggestions I’ll take a look unfortunately I cannot use a aio because I have a MSI gtx 970 in there but I’ll look into the cooler master.
You can also get a 120mm AIO in a Node 202 if you use an "ITX" GPU and widen the hole in the case cross-bar so you can get the water block through it. Bitwit cut the cross bar (see 12:00 in video)
And unfortunately I just noticed that I didn’t put my socket in my title or description because that cooler master looks like a pretty decent option but cannot fit AM4 which is a bummer.
