[SOLVED] Node not showing it iCUE?
joeryan161
30
Hi,
I recently purchased a Corsair iCUE H115i ELITE CAPELLIX that came with the commander core, i have fitted the cooler along with the commander core however the commander core is not showing within the iCUE software.
Reading around i found that running USBDeview to see if my system is actually detecting the commander core and as you can see from the attached image my system is actually detecting the commander, does anybody know why it may not be showing within the iCUE software?
Thanks.
View: https://imgur.com/5U6RpD3
de ja vu
Imagine answering same question on 2 different forums
Nope, that's how it shows up in iCUE. If you disconnect the cooler, it'll show up as a Commander Core but with the cooler connected, it shows up as the cooler.
It's different but kinda makes sense - you can't run the cooler without the Commander Core so it doesn't make sense to show the cooler by itself.
someone here might know the default setting for your AIO hub though :)
de ja vu
