I'm in the process of changing my system, and I'm focused on AMD TR systems. The important thing is that the whole system is as quiet as possible, taking into account that the system will be a non-gaming workstation (so I would exclude the possibility of overclocking).
I'm trying to get an idea as to whether a liquid system per processor and GPU can deliver less noise, or whether it's better to choose silent air heat sinks.
Would you have any suggestions?
By doing a quick search I found the be quiet DARK ROCK PRO TR4 which is given for 24 dB(A) at 100%, and then the Alpenföhn® Matterhorn Threadripper which even declare 18.2 dB(A).
I wonder how efficient this last heatsink is. I'm afraid that it won't be able to lower the CPU temperature enough, so as not to allow the CPU itself to run at maximum frequency.
Which of these two air-cooling systems do you think is the best (in terms of silence)? Or do you know more?
best regards
Max
best regards
Max
