Hi all,
I have a pretty old Clevo custom-built laptop, which used to run silent except for under the heaviest of CPU loads. However a couple of years ago this changed, and now the fan seems to be on nearly all the time, even when idle.
I notice that the CPU core temps are around 60 celsius even when idle. The fan has been swapped for a new one, vents cleaned, thermal paste re-applied, etc. but nothing makes a difference to the problem.
Could something have happened to the CPU over the years, where it now runs too hot by nature, and the fan kicks in to compensate? Or else is it an issue with the fan regulation itself?
Thanks
Thanks
