Hi I'm having issues with my rig. It keeps rebooting with high graphics cycles.
my rig:
- i7 4770k
- RAM G.SKILL Ripjaws X Series 16GB (2 x 8GB) DDR3 1866
- ASRock Fatal1ty Z87 Killer LGA 1150 Intel Z87
- PNY - Enthusiast Edition NVIDIA GeForce GTX 770 2GB GDDR5
- Sparkle gold class 850w psu (80plus)
- SB Recon3D Fatal1ty Pro.
- SSD 256 + 5 sata hdds + sata raid card with 2 sata hdd
- Seidon 240m water cooling
- 4 fans, fan controller/card reader, BD-r unit.
- cintiq 24hd 2k res for monitor, and 1080p vizio tv for gaming.
according to PSU calculator I'm fine with 850w. I'm not overclocking.
I tested:
- Prime95 (all test passed ok for at least 30min) no high temps
- Memtestx86: all test passed
- Furmark: crashes, temp gpu around 140f.
- skyrim heavely modded (but a stable release) crashes in about 5min of gameplay (@140f)
dirt showdown, plays fine most of the time. random reboots.
- rarely had any win reboots on photoshop, chrome, etc. (usually after one of the reboots mentioned with games or fur)
- also reseted the MB BIOS, I can't not get the bios update to work, it actually corrupts the eeprom,
Win8 problems:
- installed win 8, then used a 8.1 key (original) I used 8 thinking the key was good, but it was already used on my mom laptop, bought win 8.1
- having issues installing apps, some installiview wont even start installing while copying files.
- nvidia drivers installs, but hangs on updating experience at 100%, after reboot it was updated.
Things I will try after comments and things that I'm worried:
- worried about being PSU, MB, or GPU related, probably GPU, still under warranty, but under RMA 🙁 with PNY, PSU seems ok according to the other tests.
- I have to re install windows from scratch, see if it helps in any way.
- Is there any other test for the PSU?
- any way to know if the z87 is overclocking without me knowing?
any advice?
thanks in advance
my rig:
- i7 4770k
I tested:
Win8 problems:
any advice?
thanks in advance
