Non-Overclocking PC Plan Built Need advice
aldysts92
17
Hi Guys,
I am planning built a new PC this year. My purposes are for gaming and daily, but I don't want overclocking.
This is the list:
http://
Some of the parts I will get but I can't find it in pcpartpicker so I will list it here.
PSU
Max Pro 80+ 600W - EMP600AGT
Memory
Patriot DDR4 Signature Line Series PC17000 4GB - PSD4 4G 2133 x 2
And I want to ask some question about:
Upcoming CPU: Broadwell / Skylake is it worth to wait?
GPU: is it a bit over if I choose GTI 980 Ti?
MOBO: is ASUS H97 Pro Gamer good enough? Since I've read some people said it has bad software installation
Is that PSU is fine enough to hold all of my components?
Do I need CPU cooler if I don't overclock? If yes, does Hyper 212 is too much?
Sorry about my messy grammar. I hope you guys can give me some answers and solution what best for me.
Thankyou.
Good build however i7 is unnecessary and so is $100 case.
As for 980 Ti, this is the cheapest build that would support it, as you say without overclocking means a cheaper CPU and cheaper motherboard needed:
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($188.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.45 @ OutletPC)
Motherboard: MSI B85M-G43 Micro ATX LGA1150 Motherboard ($69.99 @ Directron)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($48.99 @ Newegg)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive ($80.00 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card ($649.98 @ NCIX US)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($38.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($60.00)
Total: $1206.24
Generated by PCPartPicker 2015-06-12 12:06 EDT-0400
So i5 with quad core is more than enough for my purpose?
I'm planning using patriot DDR 4 is that motherboard and CPU fine?
Do SSD brands performances give much difference? Let's say people say the best affordable SSD is 850 Evo following its performances.
thankyou for your response :)
The CPU shouldn't hinder you at all, but you could obviously get better, though the price would be driven way up.
The motherboard is on the very cheap side as well so that's the first thing I'd spend more money on if anything, but it'll still be sufficient as is.
DDR4 RAM won't give much performance increase at all.
And I have the OCZ SSD and it works fine, it has great reviews too. The Samsung isn't much more expensive though so it's still a good option, maybe even a better option due to all the love it's been getting.
Hope this helps :)
Yes thank you for your help, I still want to collect other people advice build for me so I can choose the best for me :)
Cheers.
Yep, keep on asking on forums, get as many opinions as possible and never trust all your purchases on one person's recommendations! Good luck :)
