Question NOOB ALERT! I need help choosing PC build for dual 27in 1440p monitors.
Feb 27, 2019
Hello!! This is my very first post.
I am seeking help on making decisions for PC parts for my very first build ever!
I am purchasing 2 DELL u2717d 1440p monitors. what I plan to do:
  • I WILL NOT be gaming
  • Purely for video editing and browsing
  • Occasional movie watching
  • All I want is minimum lag when I start up my computer and when I edit videos
Thank you all who come to help me in this thread. It is greatly appreciated. :)
DUAL monitor link:
https://www.dell.com/ae/business/p/dell-u2717d-monitor/pd
WildCard999
Herald
Those monitors are fine, as for minimum lag, slow startup & editing depends on your PC specs. If you don't have a SSD I'd highly recommend getting one and putting your OS onto it. Editing videos takes a decent CPU although for editing videos have you considered a 21:9 or 32:9 ratio monitor instead of two 16:9's?
Also welcome to the forum!
Feb 27, 2019
Thank you so much for the response!!
I actually have nothing for a PC yet. My main question is what I should get for all the parts. It’s a lot to ask but I’ve come here to get advice from the knowledgeable like you!
All I have is the monitors and want to know what parts I should get to make these dual monitors run smoothly (no gaming planned). Thanks!
WildCard999
Herald
For video editing/your use I'd build something like this.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($164.99 @ Amazon)
Motherboard: Gigabyte - B450 AORUS M Micro ATX AM4 Motherboard ($74.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($104.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive ($69.95 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($59.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1050 2 GB D5 Video Card ($99.99 @ Newegg)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case ($38.56 @ Amazon)
Power Supply: SeaSonic - FOCUS Gold 450 W 80+ Gold Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $653.35
Generated by PCPartPicker 2019-02-27 12:56 EST-0500
The GTX 1050 supports HDMI/DP which both displays also support.
Reactions: MezmaRiize
Feb 27, 2019
Oh wow!! Literally exactly the type of response I’m looking for. You are a savior!!
I’ll be diving into this tonight and might purchase all of these parts. I might have a few questions if that’s ok. Thank you so much Wildcard!!!!!
For anyone else that has similar or opposing opinions please feel free to share.
WildCard999
Herald
Your welcome!
For your editing your using Adobe correct? The reason I asks is for around the same price you can get a AMD RX 570 4gb which is a better video card however apparently Adobe works better with Nvidia then it does AMD on the graphics card.
