Somewhat confused by supplied power cables and which to use for the 8-PIN IN on my GTX 1080.
I have several cables with a 6+2 on one end and only 7pin on the other.
I don't have any that are 8 pin on both ends.
Am I correct in assuming that the 6+2 should plug in to my GPU, and the 7 pin into my PSU?
Can anything 'bad' happen if this is reversed?
https://imgur.com/a/lpN66
https://imgur.com/a/brqjg
