Specs:
PSU: Antec EarthWatts EA-750
OS: Win 7 64bit
MoBo: GIGABYTE GA-B75M-D3H
CPU: i7-3770K 3.5GHz
RAM: 8Gb
GPU: ASUS Geforce Strix GTX 970 Direct CUII
Hey so here is my specs and this is my problem.. I uninstalled all drivers from the previous gtx560 and all nvidia stuff. Turned off the PC, installed the new card, restart the PC and it will not boot past the BIOS screen. If i leave if for about 3minutres the screen will change to a black screen with a single underscore (_) in the top left corner. If i replace the graphics care with the old gtx560 everything is fine again and it boots to windows.
On the actual card there is 1 8pin pci-e aux input or whatever its called. Coming out of my PSU is a cable which looks like this.
http://www.bestbyte.net/index.php/athena-power-cable-ypcie628-pci-e-y-split-to-two-2-0-8-6-2.html
I am not sure if the 6+2pin going into the 8pin slot is the problem? The card has a red light on it and the fan spins but stops (I'm told these cards the fan stops below a certain temp anyway though) So there is power going into the card but i can't get past the BIOS screen into windows to install the drivers. Also with the new card install it wont let me press f8 and go into those option. I can spam f8 on restart and it just doesn't take me there.
New mobo new psu? wrong card? what am i doing wrong
OS: Win 7 64bit
RAM: 8Gb
