Noob needs help w/ Memtest86+
akahuddy
241
Hey guys, I'm trying to run Memtest86+ and am having no luck at all. I burned my .iso CD as instructed, then tried to boot up my computer. The program never begins to run. I went and googled using the program and had no luck. I tried searching the forums but couldn't get past the first page of results. 😳
Can anyone help a brother out?
Like the first reply said... your boot order is set to boot from your hard drive first. You'll probably need to press "DEL", "ESC" or maybe F2/F10 immediately after powering up your system (I'd just recommend tapping the keys repeatedly) in order to access the BIOS. This should be in your manual that came with your motherboard. Once in, somewhere in there (it varies from BIOS to BIOS) you'll see a screen that allows you to select which devices your computer attempts to boot from first. There's really no reason not to leave your CD ROM/Optical Drive as the first boot device. Just make sure that your primary hard drive appears SOMEWHERE (the bottom is fine) in that list. At that point, save your settings and restart your computer. Assuming you burned the ISO image correctly it should boot off the CD.
Btw, Memtest86 has gotta be one of the best troubleshooting applications ever... it's saved me a LOT of grief.
prime95 is easier and more effective in testing your hardware settings anyway. A LOT of memory and overclocking issues get by memtest x86 as ive seen in the past..
I had actually already changed my boot order to CD followed by HD without luck... I'll try it again and see what I can come up with.
No better luck the second time. My screen arrives here upon booting from CD:
I tried typing in the file line off of the CD without any luck. I don't have anything specified as drive A anyway so unless my system builder used a floppy to install drive and I can get a hold of one, I don't know where to go from here.
Did you try downloading from here (latest version 1.70):
http://www.memtest.org/#downiso
and download this file:
Download - Pre-Compiled Bootable ISO (.zip)
and then unzip it (extract it) to get the actual .iso file?
When making the CD, did you make sure to open the .iso file in your burning program, not drag it onto the window (which would create a normal CD with the .iso file on it, not a bootable image like you want)?
To Mondoman, that is exactly what I did the first time. I repeated the process without any luck
What happens if you type "dir" at the screen above without the quotes? The A: drive in this case is a RAMDRIVE loaded from the CD.
I'll see if I can't get something with that.
Edit: Results:
The file dates there look too old to be memtest86+, but who knows.
Perhaps try switching to drive D: (which should be your CD drive) and look for the memtest86+ program there.
OK, I just looked at my memtest86+ CD, and there is no file there, because it's in the bootsector. Also, I notice that you don't have the most recent version, V1.70.
Go to the web page in my previous post and download the specific file I listed, then unzip/extract it to get the .iso file. Then, describe exactly what steps you use(d) to create a bootable CD. I think it's converting the image file into a bootable CD that's your problem somehow.
Downloaded it last night.
Unzipped
Copied .iso file onto the CD in Nero
Burned the image on using the Bootable CD setting (possibly the mistake?)
attempted to boot from CD and no luck.
I had tried using a straight data version of 1.65 instead of a bootable CD without any luck also.
You need to use Nero to burn a CD from the iso image on your hard drive. There is no need to copy the iso file to you CD. The iso file is essentially an image of what needs to be created on the CD. Nero uses this image to burn the original CD contents on your empty CD.
Just as I was writing up a long explanation, I think I've found out what I was doing wrong. We'll see if I've figured it out within a few minutes. I'm keeping my fingers crossed.
Edit: Problem solved, Memtest86+ runs perfectly and no RAM errors. Thanks for the help guys!
As Jim noted, this was your problem. You need to *open* the .iso file as a new project; copying it onto the CD as you did just copies the file and doesn't *use it* to create a CD project.
The "Bootable CD" settings is also wrong, since the image file provides all the data/info for creating the CD.
Sounds like you finally got it working -- good job!
Yeah, it was the bootable CD option that was screwing everything up. It's good to have that working so I should be able to test out the components for my ma's rig when they come in.
Of course it's good to know that my memory checked out too.
prime95 tells you about overall system stability and results reliability. When prime95 fails, you don't know what exactly failed, so it is no substitute for a separate memory test. When prime95 fails, all you know is that something is wrong. Two real real examples that happened to me:
Example #1: I put in two sticks of DDR memory to run in dual mode on a Barton system. prime95 fails. Which stick is the problem? prime95 can't tell you, but memtest86 picked it out right away.
Example #2: I put a new cpu/memory in my system and did a slight overclock. It ran memtest all day long. Then, I booted into windows and ran prime95.... crash. The whole system rebooted. It turned out that the cpu and memory are fine with the overclock, but the hard disk/motherboard wasn't. Left alone, the system would crash about once a week. Under prime95, the system would reboot in about 20 minutes. So, prime95 doesn't tell you anything except that they system is unstable. And when it does fail, you still have to figure out what the problem is (memtest86+).
