Straight to business:
955BE
Asus m4a785td-v evo
Corsair H50 stock fans pull
HIS 5850 blower style
G. Skill 2x2gb ddr3-1600
Corsair tx750
WD caviar black 640 gb
Antec Three Hundred v1
Antec 140mm tricool intake top
H50 mounted in the back outake
2x Antec TriCool Front Intake
? Fan outake side (Antec tricool I think)
CPU OC:
3.6ghz, 1.450v, 200x18, everything else stock
GPU OC: Just let amd overdrive auto OC it with no voltage change. I believe its at 795 core and 1150 ram.
My questions are:
Is my fan configuration okay? Should I have side intake and top out?
Anything past 18 multi with 1.4875v crashes in Prime95 with in 5 minutes. Max temps are 47C in prime95 for about 2 hours. How can I OC more? More importantly how much will it help? Games I'm looking to get better performance: DayZ standalone, BF4, BF3 performance would be nice but isn't needed as it runs fine on high right now with AA and the like turned off.
How do I stability test and OC the gpu?
I am a college student so comments like upgrade your system bro will be ignored. I do plan on eventually getting a 256 gb sad and 8gb ram with 2 corsair sp fans for the rad.
The ambient temps of my room stay very low. I am in a windowless basement so were talking about 50f- 70f max normally ~63f.
I also want to start recording gameplay and am curious as to how much this would tax the system. ~15 fps drop or a lot more? I have two 120 WD caviar blue 2.5" laptop drives to use as recording storage disks for recording if need be.
Thanks!
955BE
Asus m4a785td-v evo
Corsair tx750
CPU OC:
My questions are:
Thanks!
