Noob @ PC building need MOBO help and any other advice
Kybosh
Guys,
1st build....Very excited about getting into this hobby..!! my wifes NOT
I am going to game alot and I want to put together a strong machine for Battlefield 3 comming out
here is what i have thus far
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Item #: N82E16811119225
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136533
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
2X EVGA SuperClocked 012-P3-1573-AR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP ...
Item #: N82E16814130622
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130622
Coolmax 1200W ATX12V v2.3 /EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Compatible with ...
Item #: N82E16817159123
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159123
Logitech G510 Black USB Wired Gaming Keyboard
Item #: N82E16823126100
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126100
Logitech G400 Black 8 Buttons 1 x Wheel USB Wired Optical Gaming Mouse
Item #: N82E16826104577
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104577
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model F3-12800CL9Q-16GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231478
Ozone Gaming Gear GROUND LEVEL Gaming Mouse Pad
Item #: N82E16826996056
http://www.newegg.com/Product/Product.aspx?Item=N82E16826996056
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
Item #: N82E16819115070
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Item #: N82E16835103065
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
LITE-ON Black 12X Blu-ray Burner with Blu-ray 3D feature SATA IHBS112-29 - OEM
Item #: N82E16827106346
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106346
I need a strong motherboard...I'd like to keep this under 2500 if possible..I am @ 1895.88 before shipping
along with MOBO I am planning on having 3 monitors....any advice on this?
thank you....
