Hi , this is my 1st time attempting to build or upgrade a pc , I'm was a hardcore console gamer who recently moved to the master race and only really plan on gaming with my pc , any help is appreciated
For now I only want to upgrade the MoBo and CPU
I currently have a Gigabyte F2A78M-HD2 motherboard , a AMD x4 880k CPU , a GTX 1050ti GPU , a AeroCool Integrator 500w 80+ PSU and a Fierce Rift Gaming case from Fierce Pc UK
After abit of research I Am now planning on buying a MSI B350 tomahawk Motherboard with a Ryzen 5 1600x and a better GPU at a later date , I would like to keep my power supply and case if I can but that's the main reason I'm here because I'm not sure if it will all work , here are my main concerns
Is that motherboard compatable with my case ? I'm really not sure how to tell & I cannot post a direct link to the case info so I will have to post it here
Features:
Full side window
Mesh concave front
Vibrant Red LED fans
Specification:
Front Panel: ABS+Metal Mesh
Side Panel: Windowed:
Chassis: SPCC 0.5mm, Black painting interior
PSU Port: Bottom / ATX / covered
Reserved Fan Ports:
Front: 3x12cm
Rear: 1x12cm
Drive Bays:
5.25'' exposed x0
3.5'' exposed x0
3.5'' hidden x2
2.5'' SSD x2
PCI Expansion Slots: x 7
Size: Chassis: L400*W188*H430 mm
Case: L460*W206*H470 mm
Will the 125w near silent cooler from the 880k be enough for the ryzen 1600x ?
And finally will my power supply be enough ? I will probably upgrade my GPU to a 1060 6gb at the end of the year
there's likely something I have missed so please fill me in , thank you for your time
Features:
Full side window
Mesh concave front
Specification:
Reserved Fan Ports:
Front: 3x12cm
Rear: 1x12cm
Drive Bays:
5.25'' exposed x0
3.5'' exposed x0
3.5'' hidden x2
2.5'' SSD x2
