Normal CPU Idle Temps
Dethan1999
198
Hello there! I apologize if this is in the wrong section.
I have an Intel I-7 860 (LGA-1156). I have an Arctic Alpine 11 Rev 2 Cooler. I've been told that the cooler I have is only slightly better than the stock Intel cooler, which isn't too good. Anyways, I idle around 25-38 when my room temp is fairly warm. When under extreme load, the highest I've noticed is 75-85. I was wondering if it is worth buying a better cooler. I mean, would a better cooler significantly decrease my temps? Or does the one I already have seem reasonable enough. I've heard that Sandy Bridge CPUs (mine) tend to run cooler than Ive Bridge CPUs. I guess what I'm mainly wondering is "are my temps a reason to consider a new cooler?"
Idle: 25-38
Medium Load: 45-58
Heavy Load: 75-85
Also, is there a "lowest" temp a CPU can get to? Like, is there a point when the CPUs temp can no longer decrease because it's cooled to its max? I'm not asking if having a super-cooled CPU is bad. Obviously that wouldn't make sense... (Right?)
Thanks for the help!
Ethan
The laws of Thermodynamics prevent an air cooler from getting below ambient and, in practice, the best they can do is a little above ambient.
Here's a bunch of good information on Intel Temperatures http://www.tomshardware.com/forum/id-1808604/intel-temperature-guide.html
I would prefer ten degrees or more lower under full load. I don't know how long the cooler has been in place, but perhaps the thermal paste has lost some efficiency. If the cooler has been on for three or more years, I would replace the paste and re-seat the cooler.
A good air cooler has a long life, so if you upgrade, you can likely use the cooler on a newer, ah heck, better system. If you do replace it, I would buy the cooler that I though my next system would...
A good air cooler has a long life, so if you upgrade, you can likely use the cooler on a newer, ah heck, better system. If you do replace it, I would buy the cooler that I though my next system would need.
