Normal HDD Screws don't fit my chassis Hot Swap for SSD.
Talandra
13
So recently my HDD started failing, and I decided to buy a new one, and at the same time go about and purchase that 250 GB SSD I'd been meaning to get, so I can have a few select games on it which utilize a lot of zoning/loading screens (such as Final Fantasy XIV).
I also bought a packet of 20 standard DELTACO HDD screws (the ones I got can be found here), but when I got home it turns out that I cannot use these screws to mount my SSD into the Hotswap docks on the front of my chassi, as the screws don't fit in the holes meant for the SSD to be screwed onto. I'd also like to mention that the SSD I bought (Samsung 850 EVO) didn't come with any screws inside its packaging.
They fit perfectly fine with the HDD, and I've got that plugged in and working no problem, but since I cannot fasten the SSD onto the Hotswap I cannot use it as of now, and I'd really like to know what kind of screws I'd need to make it fit, as my current SSD came already screwed on when I bought the computer pre-built.
My chassis is the Corsair Obsidian 800D, and I've looked through all the stuff that came with it, and no screws that seem to fit the SSD.
Any help with this would be greatly appreciated, as I've no idea what kind of screws I would need for this, and if possible, a link to a site where I can purchase them from Sweden.
the HARD DRIVES mounted on chassis they cant be thrown in side the case.there should be clearance for ventilation.i have laptop SSD i just trow in side cause its smaller and dont have open circuits cant make short circuit(if you know what i mean).for another storage unit i unscrew 2 bolts from my previews HARD DRIVE(usualy HARD DRIVE mounted with 4 screw).or you can unscrew one screw as a sample to byu thous screws.
