Norton power eraser
dampat
78
Hi,
I have questions regarding the results I got after I ran Norton Power Eraser. It came up with 2 bad files:
omci.sys (driver)
gamemon.des (service)
Norton could not fix either of these problems. So my questions would be, what are these files, and do I need to do something with them?
I fundamentally distrust any Norton product but these seemingly could be malformed files.
I believe omci.sys is a driver for Dell systems. Think gamemon.des is for Gameguard?
Try using MalwareBytes instead and see if you get better results / can actually remove them.
A51
As I just posted, my knowledge of computers is rather limited, which is why I rely on software like Norton to help me out. You are correct, that warning is there and I do respect it. I would appreciate your advice on ccleaner as well. It came up with alot of bad items on my computer, which is several years old, and for the most part I have no idea of what these bad items are. I have not had it do any cleaning yrt.
Ken
I've used CCleaner plenty of times and I've just let it delete whatever it finds. If you also have it clean up the registry I believe it is configured out of the box to ask you if you want to back up the registry before making changes.
