Hello,
My current setup includes 3 monitors and normal speaker (with green 3.5mm cable), and everything was working fine.
My System config - Graphic card - Zotac gtx 710; Motherboard - Gigabyte GA-H110M-H LGA 1151 M-ATX;
Monitors : 1. LG LED monitor ( 3 monitors)
Later i purchased an audio system which is -
Home theatre - SOny HT- IV 300 5.1 DOlby Digital
Now my problem is -
My graphic card has 3 ports only which i connect to the monitors and i connected the sony audio to the hdmi port of motherboard, Now i am not getting sound from the audio system.
I tried interchanging the ports from graphic card to motherboard and still I am not getting any sound
I am only able to get the sound when i connect only 2 displays and audio system, but when i connect the 3rd monitor , audio stops working.
Can u please help me out with my issue.
I really appreciate if anyone could help me out.
Thank You
Images for reference - https://imgur.com/a/mCEnWjS
Link for motherboard - https://www.amazon.in/Gigabyte-GA-H110M-H-1151-M-ATX-Motherboard/dp/B01FB6TEMC/ref=sr_1_1?ie=UTF8&qid=1541573963&sr=8-1&keywords=gigabyte+h110mh
Link for sony audio - https://www.amazon.in/Sony-HT-IV300-Digital-Theatre-System/dp/B00NTZL8CM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1541574828&sr=1-1&keywords=sony+ht+iv+300+5.1+home+theatre+system
Now my problem is -
Thank You
