I'm going to try an SLI setup for the first time using two ASUS GTX560's. They both have two 6-pin PCI-e connectors, meaning I'd need a total of four 6-pin PCI-e cables. My power supply only came with one 8-pin-to-6-pin cable and one 8-pin-to-6+2-pin cable. Basically, there's enough cables and connectors on the PSU for one card, even though it says it's SLI-ready.
My question is, what kind of cables do I need to connect two GTX560's to my PSU? I bought a cable that was a splitter of sorts -- it went from an 8-pin connector to two 6-pin connectors, BUT the 8-pin part of the cable would not fit in the 8-pin slot on my PSU.
PSU: OCZ ModXStream 700w
GPU: ASUS GTX560
GPU: ASUS GTX560
