I am putting together a PC and have an 1000w Antec pwr supply.
There are not enough connectors on the motherboard to power the 7 fans (including two for the CPU).
My question is: What is the accepted way to power these additional fans? E.g, Split a pwr socket on the M/B too two sockets? Split a pwr Cable into several sockets? And if yes, can you suggest a supplier.
I assumed that when you got a higher watt power supply this would mean extra power cables for use. But this does not appear to be the case. The 850w has the same number as the 1000w.
System details.
-Asus supercomputer m/b
-Megahalems CPU cooler
-Antec 1000 watt power supply.
System details.
