Not getting the 200mb speed I'm paying for.
m4a1drumro11
30
I just upgraded my internet with Charter Spectrum to 200 down and 10 up but I'm getting ~97 down and ~11 up according to speedtest.net. I bought a new modem and router specially for this upgrade.
Router:
Asus AC1200
https://www.amazon.com/Asus-Wireless-AC1200-Dual-Band-Router/dp/B01ATNHG36/ref=sr_1_2?ie=UTF8&qid=1525719871&sr=8-2&keywords=asus+ac1200&dpID=41DEbj41XoL&preST=_SY300_QL70_&dpSrc=srch
Modem:
NETGEAR CM700
https://www.amazon.com/gp/product/B07976SNVB/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
All settings are on default except for the DNS server on my router is set to 1.1.1.1 and my router's firmware was updated to 3.0.0.4.380_10446
Is there a way I can change the settings to get the full 200 download speed or do I need better hardware? My network setup is modem>6' cat6 cable>router>50' cat6 cable>computer and i'm using cat6 cabling for everything.
Computer specs:
OS: Windows 7 Ultimate x64
CPU: Intel i7 7700k 4.8Ghz Liquid Cooled
Mobo: Asus TUF Z270 MK2
CPU Cooler: Phanteks PH-C350I_BK C350I
GPU: Asus ROG AE8 GTX 1080 STRIX-GTX1080-A8G
RAM: Gskill DDR4 3200mhz (16GB Duel Channel)
SSD: Kingston 240G HyperX Fury(Os Drive)
SSD: Kingston 120G V300 (Games)
HDD0: WD Blue WD10EZEX 1TB 7,200 RPM(Main Storage)
HDD1: Segate 1T 5,400 RPM (Raid recovery)
HDD2: Segate 80G 5,400 RPM (OS Recovery Image)
Radiator: XSPC Raystorm 420mm
Pump: D5
Fittings: XSPC Barb
Reservoir: XSPC Raystorm Double Din 5.25" front mount.
Monitor: Asus VG248QE 24" 1ms 144hz
Monitor2: Asus VE248H 24" 2ms 60hz
Monitor3: Asus VE248H 24" 2ms 60hz
PSU: Corsair CX750M
Mouse: Razer Mamba 2012 4G
Keyboard: Razer Black Widow Chroma RGB
Mouse Mat: Corsair Vengence MM200 XL
Headset: Razer Tiamat Elite 7.1
Microphone: Blue Yeti Blackout Edition
Sound Card: Asus Xonar DSX 7.1 PCI
Case: AZZA Genesis 9000w (CSAZ-9000W)
Is anything on your ethernet path linking at only 100Mbit?
Edit your ethernet ports on your Asus AC1200 are only 10/100, not gigabit capable, you need a better router.
https://www.asus.com/us/Networking/RT-AC1200/specifications/
RJ45 for 10/100 BaseT for WAN x 1, RJ45 for 10/100 BaseT for LAN x 4
The MB supports gigabit; it has an Intel I219V NIC.
Check the "Speed & Duplex" settings and validate it's set to Auto Negotiation and not 100mbps.
Device Manager --> Intel Ethernet * --> Advanced (tab) --> Speed & Duplex (property area).
On amazon the reviews said it did have gigabyte ports. solid blue light for 10/100 and flashing blue for 1000.
Nope: Snipergod87 provided the correct link. From it "RJ45 for 10/100 BaseT for WAN x 1, RJ45 for 10/100 BaseT for LAN x 4"
Depending on where and when you bought it, you might be able to return the unit for a refund. Talk with the merchant for options.
